Results 1 to 7 of 7
Thread: The right Direction signal flasher for my SWB?
    currently the following direction signal flasher is installed in my 911:
    The installed part is similar to http://www.ebay.com/itm/New-OE-Turn-...dYbFeQ&vxp=mtr
    The signal flasher is not mounted in the original socket
    Pin #49 am #49a are connected via cable to the socket
    Pin #31 directly connected to the ground
    I'm looking for a signal flasher that fits in the existing socket and looks as original as possible (like #15 in the following picture):
    There are different offers in the market (like: http://www.sierramadrecollection.com...signal+flasher), but which one would you recommend?
    Thanks in advance for your feedback!
    Stefan
    Stefan
    xxxxxxxxxxxxxxxx911 US-delivery 130PS MJ68
    May 2006
    CT
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Thanks Tom,
    but I'm not sure if this is the right one.
    My socket hat only 3 connectors:
    and the part# should be 644 613 342 10
    ("Blinkgeber für Blinkleuchte" = Direction signal flasher)
    Please correct me if I'm wrong.
    Stefan
    Stefan
    Tom, your link is to the Hazard flasher, the OP is looking for the turn signal flasher.
    For concours you need an original hella, try ebay or samba
    might try wolfsburg west also
    ...and if not for concours => which one will work and fit into the existing socket?
    Stefan
    Stefan, the electronic ones fit in the socket and worked fine when I tried them in my '66. The one I used was the tridon EL13. Three terminals, P, X, L.
    Many thanks!
    Stefan
