Thread: Aluminium engine case studs (Flywheel end).
    Can anyone help me regarding studs on an 1967, 911 Aluminium case?
    I need a pair of engine case bearing studs that screw through the 2 dowel sleeves which are located at the flywheel end of the case.
    I think the studs are M10 at both ends and are a different length from the other 24 case studs.
    Kind regards,
    Jim.
    May 2006
    CT
    Jim
    I think these are the same studs used on the Mag cases. M10X40 (999-062-090-02) and M10X50 (999-062-039-02).
    I can pull these off one of my junk Mag cases for you.
    PM me for details
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Case studs
    Quote Originally Posted by tom1394racing View Post
    Jim
    PM me for details
    Tom,
    The M10 studs I am looking for are approximately 180mm long and are fitted at the flywheel end of the case through the the 2 dowel locating sleeves.
    These are the only 2 of that size used on the aluminium case. I don't think they are the same size on magnesium cases but I could be wrong.
    Regards,
    Jim.
    Tom,
    Regards,
    Jim.
