Results 1 to 10 of 19
Thread: Recipe for curing paint
    Jun 2003
    Bend, Oregon
    I often use white gloves to assemble things in order to avoid creating small scratches with my finger nails. Has anyone tried "baking" fresh paint to cure and harden it? Many items I paint will fit in my wife's oven and I have a lot of opportunity to use it when she is out of the house teaching.
    If you use this method, what are your settings: degrees and time? Is it effective?
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    When I was young and dumb I spray painted my VW J pipes with rattle can Flat White heat paint. The instructions said it has a 5 day cure time so I blasted them at full noise in my mothers oven for 2 hours. The paint job outcome was fantastic, my mothers reaction was not.
    I know others who have sprayed brake calipers with paint that is designed to be baked but I do not think that your "standard" rattle can paint is designed to be oven cured.
    Mark
    Apr 2012
    Simi Valley Ca
    I cooked every piece of sheet metal of this 356 motor in my BBQ. About 20 minutes at relatively low heat. Unfortunately I haven't heard back from the owner, but I figured it wouldn't hurt to give it a try.
    Straightening, welding and prepping all those pieces was the hardest part of this assembly. Spent almost a whole day on the heater boxes.
    Bob B
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    i do have one of those
    https://www.google.at/search?client=...3wN9mJfprVnYM:
    works perfect to cure small parts and breeding eggs.
    spares you a lot of time and fingerprint hassle
    When I rebuilt my 3.0 earlier this year I painted the stuff that needed it with VHT black hi temp engine enamel, or the VHT satin clear. Both are very very durable when cured properly. Depending on the product, the cure temps and times vary. The VHT product has very specific directions on the back of the can. It's usually around 200 deg. for a half hour, then let cool, bump up the temp and repeat, but again, it varies with the product. I picked up a working used oven for nothing and wired up a 220V outlet in my garage. When I'm not baking stuff, I use it for storage and a workbench for light use. The tins on my engine look great, and still look great after 6000 miles.
    Early S Registry Member #3291
    Still hunting for my dad's (Roger Abraham) '70T Coupe in Light Ivory
    Purchased new from Gruber Porsche Cedar Rapids, IA
    I painted this shift knob with enamel and then baked it for 1hr @ 225 degrees farenheit. The paint is rock hard and flowed and shines beautifully. If it fits in the oven it's my new paint technique. Just let it come down to room temp on it's own, don't touch it or try and rush the process.
    I've since gone back and retouched the black and red paint. That was done afterwards by hand. In the picture the knob looks matte but it is actually nice and shiny. It's more a reflection of my photography skill than my spray painting skill.
    Nov 2014
    Port Orange, FL
    I like the 2-part polyurethane paints. For small parts an airbrush is ideal -- and you can mix it up with measuring spoons, as the stuff is expen$sive!. I do this outside, as it is VERY toxic, but it forms a durable, high-gloss finish, if used with epoxy primers (again, quite toxic). Use a mask and vinyl gloves when handling both paints.
    May 2006
    CT
    I use my backyard gas grill instead of my wife's oven. Better domestic harmony.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Quote Originally Posted by Jameel View Post
    Nice work!
    Early S Registry #235
    rgruppe #111
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by tom1394racing View Post
    yep..went down this road once ...
    ....the first batch of rs clock covers...the day after i bought the clay oven
