Thread: Dimension hole + Mounting antenna on a 65-66 911
    Hello,
    The replacement front fender of our car did not have a radio-hole behind the fuel gasket.
    But the car did have a radio.
    Now we want to make a correct hole for the antenna.
    Does somebody know the exact dimension of the hole + position and dimension of this hole relative to the fuel gasket?
    Also wondering if from the inside of the front fender there needs to be welded something to attached the antenna?
    Or is this only with a fixed bracket like in the picture? (Pictures is from a antenna on the passenger side). So don't know if there is any difference in the way of mounting it.
    Feb 2013
    Europe
    Relative to the fender rear
    So 265mm from the most outward point of the front fender to the middle of the hole.
    So 95mm from the middel of the hole to which edge? The edge between luggage compartment lid and the front fender?
    Also dimensions of the hole?
    Quote Originally Posted by Adore911 View Post
Tags for this Thread
