Thread: 46 MM webers
    46 MM webers
    Hello
    Where to send the carbs to be rebuilt back to ORIGINAL?
    I have 4 46 MM webers (2) new in box and (2) used. The new in the box 1 got water damage bottom 1/2 the other is mint. Second set are just used and need complete rebuild.
    I have a place that can rebuild but don't do the coating to make them look new.
    Thanks George
    Paul Abbott
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Matt Blast, Eurometrix.....doing it forever. Does the original finish, plating, machining. Reasonable turn around.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
