Thread: Correct Hella fog lights for 1972 911T
    Dec 2013
    Connecticut/Florida
    My 911T came with fog lights but a prior owner removed them at some point. This is a picture of the support bracket behind the cover. Can someone tell me the correct Hella model and the right bolt/post that should be on the light to connect to the bracket?
    Attachment 435299
    1971 911S Coupe - Gemini Blue
    Dec 2013
    Connecticut/Florida
    Help please ��
    Jul 2011
    Chicago Area
    Here you go: http://www.early911sregistry.org/for...139+fog+lights
    Well those are sold but you need the Hella 139's with the rear mounting bolt in the center, not top or bottom. You can use clear lens or yellow.
    Sierra Madre has them new: http://www.sierramadrecollection.com...73-p18274.html
    Mike Fitton # 2071
    2018 911S Carrera White
    Dec 2013
    Connecticut/Florida
    Thanks. The 139 has one bolt in the center for attachment. However, the bracket as two horizontal holes. How is it attached to the bracket?
    Senior Member nvr2mny's Avatar
    Mar 2012
    Kansas City
    If you're looking for an NOS set of 139's, I have a pair currently listed.
