Results 1 to 10 of 10
Thread: 1970 911 front carpet mat options??
Hybrid View
    I am looking for floor mats to cover the original factory carpeting and am only finding mats with holes/grommets as used on the later 911s, or the current version of CoCo mats that have a rubber underside and therefore an overall thickness more than I want. Has anyone found a supplier/style that they would recommend? Thank you.
    Jul 2006
    Switzerland
    If you go for period look, only Cocomat are correct, although back then Sisal mats were also a factory option.
    Nothing else was available and even today's Cocomats have a rubber backing, they look great and are very well fabricated. The rubber back prevents they are gliding, of what the original ones did.
    Whatever else you choose is up to you but never will be period correct.
    What also people forget is that Porsche never wanted their name been stepped on by shoes with the heels, hence the Porsche name is always sideways near Rocker panel, never heel area. Even today.
    First thing also to spot an aftermarket item.
    1970 Accessory folder
    1971 Accessory folder
    Registry member No.773
    Nov 2016
    Munich, Germany
    Seems like there existed 2 mat designs back then. The one on the first cataloque page has holes for the pedals the other one (as the ones supplied now from e.g. cocomats.com) has the tongue end just before the pedals.
    Does anyone know a source for the one's going all around the pedals? I am looking for a style just like this:Name:  7391004394_3bb90f57b7_o.jpg
    Jul 2006
    Switzerland
    Nobody makes repro according to the earlier style w pedall cut-outs.
    Cocomats are the only one being close and in good quality.
    You do can supply a template to Cocomats and they do it, for a special price.
    Otherwise, you need to find period used ones (i beleive as seeing above) which is not easy. to find.
    Jul 2011
    Chicago Area
    Cocomats should already have the template for around the pedals just ask, they also have the center piece that goes around the shifter.
    Mike Fitton # 2071
    2018 911S Carrera White
    Aug 2005
    Bucks Co., PA, USA
    Quote Originally Posted by mfitton View Post
    They do have it. This is an old photo of my car, taken just after I bought it; things look a little tidier in there now. A set of Cocomats was the first non-mechanical purchase I made. I didn't opt for the mat around the shifter.
    ESR #1474
