Results 1 to 7 of 7
Thread: Momo vs Nardi spacing ?
    Does anyone know if the Momo mounting holes spacing is the same as Nardi, for steering wheels...
    I need a 390mm wheel and cannot find any Momos that are not breaking the bank, Nardi has nice wheels all day long for $350 but I have the Momo adapter already and horn button (this is for my 2002, not 911, purists may relax)... For that matter: the horn button hole diameter as well, if anyone could confirm that would be great !
    Edit: found out bout nardi to momo hub adapters, adds spacing but it's fine. Still unsure about the horn button diameter though...
    Greg.
    72 911T - 73 2002
    #1461
    Oct 2011
    The land of fruits and Nuts
    99% sure the horn button diameter is the same.
    Porsche taste on a Volkswagen budget...
    Senior Member NickP's Avatar
    Mar 2006
    Solana Beach, CA
    Horn button diameter is different: Nardi = 60mm, Momo = 55mm.
    Nick Psyllos
    S Reg & R Gruppe
    1973 Euro 911S
    1972 911T to ST
    Oct 2011
    hmm I've used a nardi button on my momo. I guess it's possible to go one way but not the other?
    Mar 2006
    Solana Beach, CA
    I measured both openings on each steering wheel. Maybe the flange on the hub would allow for a different horn button to fit;it would seem logical the the Momo button would fit the Nardi. I’ve got both a Nardi and a Momo sitting on my workbench, I’ll go mess around with em’ and see what fits. I have a slick little spacer that effectively reduces the diameter of the Nardi hub which allows the common Momo button to fit.
    Nick Psyllos
    S Reg & R Gruppe
    1973 Euro 911S
    1972 911T to ST
    Feb 2011
    Northern VA
    Bolt spacing is DEFINITELY NOT the same. However, if you have a nardi, you can get a cheap ($15 bucks or so) adapter off ebay that will allow you to put a momo wheel on a nardi hub
    Thanks... So I'd need to add the adapter and I'd lose the button, possibly. I'm going to keep looking for any old momo in 380 to 400mm. Ironically I have a spare 400mm 911 wheel, but the spline might be different... gotta try, would be a good use for that wheel !
    Greg.
    72 911T - 73 2002
    #1461
