Results 1 to 2 of 2
Thread: Dashboard Fascia Removal
    I am hung up on removing the last piece of the dashboard fascia backing plate. The first 2 sections on the passenger side practically fell off. The driver's side was a little tougher as the plastic(?) retainer clips on the 47 yr. old hazard flasher were so brittle they snapped - no big deal. The middle section (c/w heater slide control levers) in the photo is the piece in question.
    It almost seems as though there is a fastener or something holding this piece on. I have done the obligatory search & found there is precious little in the archives on the "how to" on this subject so...
    What am I missing doing to remove this without buggering things up?
    Any thoughts or advice on my problem will be greatly appreciated. Thanks in advance.
    Cheers
    JB
    This is a copy of my post on PP - there doesn't seem to be the same level of interest in the early cars there so I am hoping for better luck here.
    Success is not final, failure is not fatal: it is the courage to continue that counts. - Winston Churchill
    Early 911S Registry Member #3749
    Shift Knob Maker
    Oct 2004
    Marysville, OH
    Have you removed the heater controls and radio? They need to be removed first. It is just held on by double stick tape, a thin putty knife slid up underneath with do it. Don't pull on it, it will bend easily and is very difficult to get straight again.
    Mark..
