Thread: Becker Frankfurt squealing - help needed
    Member 66DC's Avatar
    Apr 2011
    Washington DC
    It used to work fine -- now, no sound and this weird squealing:
    https://www.youtube.com/watch?v=iEnH9QEmDas
    Any advice?
    1966 911 coupe, Granite Green
    Nov 2002
    San Dimas, CA
    I've earned two degrees in electrical engineering but that was 30 years ago and I remember very little about heterodyne receivers and amplifiers.
    The only thing I can think of that you might repair at home is that the antenna is no longer connected. Either the coaxial cable was pulled out of the radio or it's been damaged.
    • The center conductor should have zero ohms to the antenna mast and infinite (or at least really high) resistance to the car's body.
    • The outer conductor should have infinite (or at least really high) resistance to the antenna mast and sero ohms to the car's body.
    If it's not an antenna problem you'll probably have to send it to a pro anyway.
    By the way, that's a Blaupunkt Frankfurt. The comparable Becker radio was the Europa.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    1st Contact ???
    Mark
    Jul 2003
    Santa Cruz, CA
    The squealing is a high frequency feedback. Bad antenna connections usually result in static/crackling sounds. Could be in the RF or IF sections. Could be filter caps that are shot and allowing the noise feedback.
    Sounds like a trip to the bench to me.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Senior Member mathieulecomte's Avatar
    Dec 2016
    New Jersey
    You should try to contact Stephan at SW Stereo. He's not far from you in NJ. I sent him my 64/65 Essen radio and he had no problem fixing it. I would strongly suggest calling him rather than email, that works best. He's very talented with old Blaupunkts
    http://www.swstereo.com/
