Thread: FS: 1975 914 with early sand cast aluminum 2.7L engine
    The one of a kind engine is built as a tribute to the Porsche air cooled engine design with components and improvements considered the best over the 30+ year history of the 911 engine design evolutions.
    Engine approximately 5000 miles on rebuild
    - 1968 early sand cast case (#3380133) bored for 2.7, oil bypass modification, oil squirters added. Work done by Ollies
    - Original 911S 8.5:1 CIS pistons and Nikasil cylinders.
    - 74 911S heads with 46/40 valves rebuilt by Ted Robinson at German Precision.
    - 94 993 cams with keyway, 993 cam towers, 993 valve covers and 993 hydraulic lifters.
    - Hydraulic chain tensioners.
    - 911SC aluminum 4 rib oil pump 911-107-008-05
    - Original 74 911S CIS fuel injection.
    - Genuine 914-6 oil tank.
    Exhaust
    993 heat exchangers into dual inlet stock muffler
    Wheels
    Genuine Fuchs alloys, rear are deep sixes
    Brakes and suspension
    - Front 911S front struts, calipers and rotors with 3.5" caliper mounting
    - Rear 911S calipers and rotors with drum-in-hat parking brake
    - 180lb rear springs
    MSD electronic ignition and distributor module.
    Body in original condition except for paint. Original paint was L97B Anacona Blue Metallic. No rust.
    Owned since 1987
    Senior Member 767driver's Avatar
    Oct 2008
    Parkton, MD
    Sounds like a cool car...can we get some pics posted?
    Lee Fishpaw
    O Gruppe #20
    Early S Reg #2175
    R Gruppe #714
    '70 914-6
    '88 911
    '85 928S
    '74 260Z
    '74 TR6
    pictures posted
