Results 1 to 10 of 12
Thread: Help on this connector
    Dec 2013
    Connecticut/Florida
    Does anyone know what this connector on the heat exchanger connects to? Does it connect to the heater box? Thanks
    1971 911S Coupe - Gemini Blue
    Lightbulb
    It connects to a matched 'connector' directly above it at the bottom of the left side engine sheet metal... the top side of the sheet metal has a wide wire screen over the open pipe.... Looks like you have mismatch between your heat exchanger and sheet metal...
    This is what my '73 looks like from the bottom....
    Hope this helps,
    cm
    Dec 2013
    Connecticut/Florida
    I wonder which isn't correct. My car is a 1972
    72's didn't have that intake.
    The heat exchanger in your pix is late 73.
    Dec 2013
    Connecticut/Florida
    Does anyone have a picture of the drivers side heat exchanger for a 1972T / MFI?
    May 2006
    CT
    I think this is the 2.4 MFI LHS heat exchanger where in the short snorkel inlet thermo-flap inlet is used.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Tom, that is the mid year 73 exchanger, someone has to have a 72/ early 73.
    Dec 2013
    Connecticut/Florida
    Its confusing because many who offer the MFI one for sale show the short snorkel as well
    That's so they don't have to stock TWO slow moving parts. For a 73 just attach hose and go, for a 72 just cap off the outlet. Unfortunately it's not 1972 anymore.
