Thread: Case studs.
    Case studs.
    Can anyone help?
    I am looking for a pair of 911 engine case studs 175mm log , M10 x 1.5mm threads at both ends.
    These studs go in into the dowel sleeves at the No 1 bearing/ flywheel end of the case.
    Regards,
    Jim.
    May 2006
    CT
    I can pull a pair out of a junk case. PM me for details.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Tom,
    Thanks very much for your reply.
    From you junk case could you please tell me that the 2 studs are approx. 175mm total length and M10 x 1.5mm threads both ends. If they are, that would be great.
    The reason I am asking, is because the later case studs were M10 x 1.0mm fine thread one end and M10 x 1.5mm at the other end.
    Please let me know how much you want for the studs plus postage and if you are willing to send them to me in the UK.
    Kind regards,
    Jim.
    Tom,
    Kind regards,
    Jim.
