Results 1 to 5 of 5
Thread: 1967S side moulding location and hardware?
    Nov 2015
    Looking to install the correct trim on my 67S.
    The car was restored in 1981 and never had the trim fitted.
    I have the new trim piece.
    I am looking for the measurement for the correct location of the side trim and the correct type of hardware to use?
    www.tcspeed.com
    Nov 2015
    no advice?
    www.tcspeed.com
    start here:
    http://www.early911sregistry.org/for...lding-question
    Google has a very nice search engine that will search this site with great detail:
    Type in :
    site:early911sregistry.org correct pliers 68S - Google search
    replace the subject "correct pliers 68S" with the topic you would like to see. Let me know if this still works.
    Bob
    Early S Reg #370
    The search as posted will help greatly.
    Also believe this trim comes with the correct locations for attachment.
    I just attached new S trim and found the trim had the correct locations for attachment to body.
    Remember the rubber trim covers the body attachments and should be trimmed at ends at proper angle.
    Do not cut until you have test fit for length of the rubber.
    You only get one try at this....good luck
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    Nov 2015
    would like to add that my car has no holes in the rockers for screws. It is a blank canvas, hence im trying to see what screws to use and how low do i mount the strip below the door.
    www.tcspeed.com
