Results 1 to 10 of 12
Thread: silvered back of turn signal lenses
    Hello,
    I have a 69 911 S and my front and rear turn signal lenses are in great shape, except for the silvered portion on the back edges flaking off. Does anyone have a good paint or other coating I could apply to restore the silvered edges?
    Thank you,
    Jim
    Jim F.
    1969 911S
    member 1864
    All is answered 13 threads down this page.
    Jul 2014
    Long Island NY
    Ed has guided you to the narration, and the answer in a word, no.
    Thank you. There certainly has been extensive discussion of issue!
    Jim F.
    1969 911S
    member 1864
    Quote Originally Posted by jimf42 View Post
    Thank you. There certainly hasn't been extensive discussion of issue!
    Yes, there has, ad nauseam.
    Maybe someone will hire upon a technique for re-silvering.
    Jim F.
    1969 911S
    member 1864
    Jul 2011
    Chicago Area
    Jim I got your PM on this. I have an idea to try using silver Mylar tape with clear adhesive on one side but I don't have a lens to try it on. Anyone want to send me a throwaway silver edged lens to experiment with? It can be crazed or crack or even broken in half as long as there is 6 or 8 inches of old silver edge to test this on.
    Mike Fitton # 2071
    2018 911S Carrera White
    silvered back of turn signal lenses Your Message
    that sounds promising..hopefully, someone can come up with a lens
    Quote Originally Posted by mfitton View Post
    Jim F.
    1969 911S
    member 1864
    Yes, there is a techinque. It called vacuum vaporised aluminium. It will reproduce the original "chrome" finish.But the final quality depends on the preparing. You have to polish the frame to crystal clear.
    Jul 2011
    Chicago Area
    Quote Originally Posted by lrogacs View Post
    Yes the key to success is polishing the gutter as crystal clear as possible.
    Mike Fitton # 2071
