Results 1 to 9 of 9
Thread: new ignition/door keys
    Hi,
    I while ago I received the original ignition/door key blanks from Tony Euganeo and had them cut by a local locksmith using my old example.
    Unfortunately, I can't turn the key in the ignition lock even though it was made as a exact copy. I believe that the new key has the correct pattern/cuts
    as the locksmith was using his copy machine one more time on it-he mentioned that no more material was cut the second time and when looking at both
    the old and new keys they look identical. Has anyone some ideas what the problem could be and how to fix it?
    Thanks in advance for any help.
    Regards.
    Stefan Menn
    Sep 2013
    Vancouver, WA
    Does the key work in the passenger side door lock? The passenger side tends to wear less as it gets used less. I would take the door lock cylinder out and put the new key in it. If you have a wafer that is sticking up, push down on it. If you can't push it down it means the key needs to be cut more. If you can push down and it's springs back up then it's cut too much. Other than that you could try some powdered graphite in the ignition lock and see if something is sticking. In other words I would try everything I could before trying to open up the ignition. That's a real pain.
    Something is obviously different. If the original key is worn at all, cutting a new key from a worn key with even the slightest variation could give you trouble.
    Dec 2015
    Bordeaux, France
    If you take the lock cylinder out, just take a file and smooth out any pieces that are sticking out. Everything should be flush when the key is fully inserted. Then, your new key will work just fine.
    ____o0o____
    1972 Targa 911S (one day), silver gray (maybe), member 3337
    Sep 2013
    Vancouver, WA
    His problem is in his ignition though. Using the passenger door lock is just an easier way to possibly find the problem.
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    TWEETS Restorations -- For all of your key and lock needs
    DRROCKETDAN@gmail.com
    http://stores.ebay.com/type4andmore/
    http://www.ebay.com/sch/type4_plus/m......ipg=&_from=
    http://www.914world.com/bbs2/index.php?showtopic=214952
    Memberships: 914World, 914Club, PelicanParts, TheSamba, Porsche356Registry, 912bbs
    I believe he is a member here too......
    Goes by tweet on the Sregistry
    Quote Originally Posted by Cliff View Post
    Thanks to the early S registry and the lead to TWEETS, I just received a new complete set of (2) red and (2) black keys for my 72 911 and will be having them do their same magic for my 70 911. Superb work and superb customer service...could not be happier with the experience!
    Senior Member damsroy's Avatar
    Jun 2007
    Connecticut
    They did great for for my 73 911 too. Very good experience.
    Early 911 S Registry member #3308
    911E 1973 - Brownie- 66k original miles - Second owner
    911E 1971 - gold metallic - sold and missed
    912 1966 - sold
    Member tweet's Avatar
    Jun 2016
    South Florida
    Quote Originally Posted by excelpflyer View Post
    Hi,
    Regards.
    Stefan Menn
    Hello Stefan,
    I don't know if you have been able to resolve your key/lock issue. There are different reasons your key may not operate your ignition. The ignition has a very tight tolerance. Even a small deviation in the depth of a cut is enough to cause a jam in the lock cylinder. The only keys we duplicate are ones that we can verify are good candidates for duplication. Most auto keys should not be duplicated but instead cut to code. Even after we cut keys for customers, we go back and do a mock up of the lock and test each and every key we make, multiple times to ensure proper operation before shipping back. We perform quality control tests. Most of the time a copy of the key will not work because copies are even more problematic than the key that is being copied. Copying a key that is a duplicate, duplicates of duplicates, worn keys, damaged keys (bowed, bent, twisted), and irregular will only lead to problems. In the rare event that a key is a good candidate for duplication, then the problem will reside in the lock itself. If your key is properly cut, then you have a problem in your ignition which needs to be addressed. And by the way, it is also common for key duplicates to look correct, but are not. A locksmith will not usually admit he didn't cut your key correctly. We can inspect your ignition and all your keys and identify and correct the issue.
    Jun 2016
    South Florida
    Thank you so much to all our happy customers for the positive feedback. It was a pleasure working with each and every one of you. We are glad to be of service and strive for excellence. Happy New Year to all!
    Regards,
    Alicia & Dan
