Thread: Halda gears for Avon 215/60/15 ?
    Nov 2004
    New Zealand
    Does anyone have a halda unit in their car fitted with an Avon 215/60/15 tyre on a 7" rim?
    Can you share what X & Z gears you have installed please?
    My car is in pieces, 4 hours away, and I can't do a distance check then order cogs to arrive here in time.
    Hoping someone may have a ready answer...
    I guess the other way is to figure out the the % difference in the circumference of the old tyre, compared to the new, and adjust the cogs accordingly?
    It would be nice to have a real world solution to check against my math in any case!
    thanks in advance
    nathan
    Senior Member Darren65's Avatar
    Aug 2011
    UK
    Hi Nathan,
    Just had my Halda serviced and checked my calibration today........running deep 6 and 7R's with 185/70 and 215/60 Avons I found I need X=140 and Z=39 optimum.
    Probably a little late for you but would be interested to hear your results, I'm guessing these all vary?
    Cheers,
    Nov 2004
    New Zealand
    Hey Darren, thanks for the reply.
    I am not sure I am going to be much help, my guess is you are working in MPH?
    I need to display in KMs (NZ went metric in 1974, so my 1969 car was delivered with MPH gauges)
    I haven't checked against a GPS yet, as the cogs arrived too late to use last year and I have only recently installed them.
    My starting point was X=128 and Z=58, for a 205/60/15 on a 7r rear wheel.
    I have put in a X=127 and Z=58 for the taller Avons, and just need to get out and test this.
    I will follow up with a post once this is done.
    thanks
    nathan
    Aug 2011
    UK
    Thanks Nathan,
    I asked my Halda service agent which cogs I would need for KM's based on the information I had given him and he came back with 129 and 58 although suggested I first check my mile gears to gauge how accurate they are reading.
    Obviously very close to where you're at
    Cheers,
