Results 1 to 8 of 8
Thread: Help - Tunnel Route for MFI Return Fuel Line?
    May 2006
    CT
    I am reinstalling the hard fuel tube for the MFI return and I would like to ensure I have the proper routing in the tunnel to avoid any obstructions. I know where it enters and exits the tunnel. It appears that the supply line is routed through a channel at the upper LHS of the tunnel similar to the routing of the wiring harness on the RHS. The photo shows the supply line entering the channel inside the tunnel, just above the throttle rod, as seen from the rear of the car. My question is....
    How does the return line route? Does it go through the same tunnel? If not, what it the route?
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Jul 2006
    Corvallis, OR
    Yes, both go through the tunnel.
    72S, 72T now ST
    May 2006
    CT
    Scott
    Thanks for your reply...Just to confirm...The return line goes through the same channel, above the throttle rod, as the supply line. Is that correct?
    Tom Butler
    1973 RSR Clone
    1970 911E
    May 2006
    CT
    OK. Took me all afternoon to get the new solid tubing through the channel and out the front firewall. Getting the front section through the plastic guide tube and out the firewall was challenging. I had to make a guide tube out of a section of brake tubing to guide the front out the firewall hole. Glad that’s over with.
    Tom Butler
    1973 RSR Clone
    1970 911E
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    Good sh.t
    Ask a bit of advice ,,
    Get it,,
    Job done in under 12
    Mark
    May 2006
    CT
    Yes..... I am continually amazed by the depth of experience and knowledge along with the good advice available here.
    Tom Butler
    1973 RSR Clone
    1970 911E
    Jul 2006
    Corvallis, OR
    Tom, I can takes pics for you but it looks like you're done. If you still want them let me know. I have a 71 I can take pics of for you.
    Quote Originally Posted by tom1394racing View Post
    72S, 72T now ST
    May 2006
    CT
    Hi Scott...thanks for the offer but I think I have it all set.
    Tom Butler
    1973 RSR Clone
    1970 911E
