Results 1 to 8 of 8
Thread: 911/01 transmission case
    Aug 2010
    Colorado
    70/71 E/S transmission case. PM if interested.
    $500 plus shipping.
    Chris
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    Quote Originally Posted by cmpski View Post
    Chris, it appears that the clutch cable tab on the bellhousing of the case has been cut off.
    If so, that's a significant modification that you should make people aware of.
    Jon B.
    Vista, CA
    Aug 2010
    Colorado
    Jon,
    Thanks, I'll look into that.
    www.reSeeWorks.com
    Aug 2010
    Colorado
    Jon,
    You have a picture. I can't find a spot that looks cut off.
    Here are some more pictures. It has a piece that allows the use of a 2 liter shift fork. I'll also throw in a open diff and cv output flanges.
    Chris
    www.reSeeWorks.com
    Transmission Number Reference = 7103501
    Peter Kane
    '72 911S Targa
    Aug 2010
    Colorado
    I cleaned the trans some and found where the tab broke off. I guess I'll remove the studs, nose cone, and intermediate plate. The case will be recycled.
    Consider this item NLA.
    I'll post the parts here.
    http://www.early911sregistry.org/for...smission-stuff
    www.reSeeWorks.com
    Jon, You have a picture. I can't find a spot that looks cut off.
    Chris, this is the part of your case that appears to be cut off in your first photo.
    Jon B.
    Vista, CA
    Aug 2010
    Colorado
    Well after taking all the studs out I looked even closer at the case. The tab was cut off on purpose and converted to work like my 69 case. See picture. Then a ball was welded to another piece of metal and bolted in so the trans now works like a 69 2 liter transmission to avoid the issues of the 70/71. So it's back for sell, but for $350.00. The transmission sat around for 25 or 30 years so someone back in the day came up with this fix.
    www.reSeeWorks.com
