i have two sets of wheel hubs for my 1969T.
How does one know when and how to restore them and when to ditch them?
www.tcspeed.com
are new available?
www.tcspeed.com
anybody know if there is somebody who restores them?
www.tcspeed.com
Assuming you're speaking of the front hubs with the wheel bearings in them? Disassemble, clean, level of cleaning up to you. Remove bearings and races, replace all, repack with fresh wheel bearing grease, and new seals.
How crazy do you want to get??
Ed outlined a proper mechanical restoration....
The cosmetics would involve:
Remove inner seal
Press out studs and bearing races
Glass bead, polish, and re-clear anodize hub body
Re-black oxide studs
Press in new bearing races and refinished studs
Pack new bearings
Install inner bearing and press in new seal
Re-install on spindle with new outer bearing and adjust
Viola!
Mark Smedley
'59 VW Typ I
'69 911T 2.7
'86 930
'04 GT3
'16 Boxster GTS
After complete disassembly and cleaning, we ceramic tumble the hubs, they come out like new. The hubs are bare ALU, we didn't find any coatings. Gordon
Mark Smedley
'59 VW Typ I
'69 911T 2.7
'86 930
'04 GT3
'16 Boxster GTS
The ones on my '65 were clear anodized. Luckily they were in such nice shape after ultrasonic cleaning that I just decided to leave them and not have the anodizing re-done. Black phosphate the suds, grey phosphate the dust caps put in new races, pack the bearings and they will be good for another 50 years
thanks fellas!
www.tcspeed.com
