Thread: WTB: 73 Short horn and mount for it.
    I'm guessing that these piggyback onto one another, and my car has just a long horn with a cracked plastic trumpet, and needs a short horn and mount.
    I'm looking for a complete short horn
    Bracket to tie these together
    Plastic trumpet if you have it
    Anyone have piece parts that I could put this back together with?
    Thank you!
    Are you after banjo style which has a long and a short or trumpet style which also has long and short
    Do you want the style in the pic (trumpet)
    The brackets for either do not tie the horns together they are seperate brackets for each and I have reproduction brackets for both styles available.
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Thanks Clyde.
    Is that photo from Boyer that you added? No, I need the short one + bracket for a 1973 T. His was the repaired long one.
    I also need a replacement plastic horn (minus the diaphragm) if that's possible for the long horn, as mine is broken at the end.
    No I am BOYER73S, one in the same, it was one I found quickly on this site.
    This is all I have for the style of horns you want.
    http://www.early911sregistry.org/for...-and-they-work!!
    plus I do make these and have some in stock, correct brackets for the horns you seek.
    http://www.early911sregistry.org/for...-trumpet-horns
    Clyde Boyer
    Ah, it is you. Thanks!
    The banjo style has the horn coming out of the side, I think mine is like yours as pictured above. Size wise, that looks like the long one, and I could use a long horn (without the piezo buzzer) and a short complete unit.
    I thought they "daisy changed" so I need to see if my bracket is in there inside the bumper...
Tags for this Thread
