Thread: 3.2 Pump in a 71 case
    Senior Member sebastianroher's Avatar
    Jan 2015
    Florida
    I'm about to start assembly on my bottom end of the motor. I'm thinking about installing a new 3.2 pump instead of using the stock mag pump. Will I have to do any modifications to the case? I already have the oil bypass mod and piston squirters installed.
    Sebastian
    1971 911t coupe
    2002 Camaro z/28
    Oct 2010
    Southern Ca.
    No modifications required . You will have to use a 3.2 sump plate to go with the pick-up screen .
    Jan 2015
    Florida
    Quote Originally Posted by Richy View Post
    Thanks Richy!
    1971 911t coupe
    2002 Camaro z/28
