Thread: Help - Installing a SWB 901 Gearbox into a '69 Car
    May 2006
    CT
    I have a customer with an early 901 gearbox with the SWB output shafts that he would like to install into a '69T. At first, I thought no problem just install the later '69 compatible output shafts into the gearbox. However, it is apparently not that simple. Do we need to swap a '69 differential into the earlier 901 gearbox? Or do we need to modify the SWB output shafts by welding and machining to accept the '69 CV's?
    What is the best approach short of getting a '69 gearbox?
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Aug 2010
    Colorado
    I have a 69 open diff and output shafts on my shelf if that is a solution.
    Chris
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    May 2006
    CT
    I suspect that a '69 diff from a chill cast Al case '69 gearbox will work. The later, '69 Mag cast gearbox takes a different differential case and bearings.
    Tom Butler
    1973 RSR Clone
    1970 911E
    Aug 2009
    SF Bay Area
    You can use a diff from a 68 or early chill cast 69 trans. The flanges have to come from a 69 chill cast trans, though.
    Jim
    May 2006
    CT
    Jim
    Thanks much...Makes sense. I have located those parts here in CT.
    Tom Butler
    1973 RSR Clone
    1970 911E
