Results 1 to 9 of 9
Thread: 1969T gas tank options?
    Senior Member tcsracing1's Avatar
    Nov 2015
    Somewhere in a galaxy far, far away....
    I am now restoring the front trunk area in my 69T "hotrod".
    I have a full size spare 15x6 deep 6 on Avon tire for the front trunk and would like to have a gas tank that allows fitment.
    Would the plastic RS tank allow me to still fit the full size spare?
    Any suggestions for tank options would be much appreciated.
    www.tcspeed.com
    The RS tank requires a collapsible spare, as does the SC tank. You need either the stock 62 liter tank or the 100 liter one.
    Nov 2015
    thanks,
    either tank available in light weight plastic?
    www.tcspeed.com
    The 62 only came in steel, the 100 at one time came in plastic, made by BASF. I have one of those, but has bottom leaks, more often the 100 liter ones were steel.
    Feb 2005
    Lake Tapps, WA
    I have a brand new plastic tank if you are looking for one.
    '67 911S
    '69 911S
    '70 911ST
    '73 911T Targa Signal Yellow
    '11 Spyder
    Early S#1097, R-gruppe #
    Nov 2015
    what model years offered the 100L plastic tank?
    www.tcspeed.com
    To the best of my knowledge the plastic was 67-68 time frame, steel came after that.
    Nov 2015
    pros/cons of plastic tank?
    www.tcspeed.com
    Pro is less weight,,, con, some may say it is a safety concern.
