Results 1 to 9 of 9
Thread: Fog light and Defroster wires
    Dec 2013
    Connecticut/Florida
    I'm going crazy trying to figure out the wiring that isn't correct at the back of mt Fog light switch and defroster switch. Photo one shows the rear of the two switches - Defrost on top (green jumper), Photo 2 is a close up of the fog switch (red jumper) and photo 3 the wires not connected. Any help with connections would be appreciated.
    Defrost has a Green jumper, a double black, a brown and a red with blk strip. It has two spades without wires
    The Fog has a red jumper and a black wire . It also has two spades without wires
Size:  115.8 KBName:  IMG_6603.JPG
Size:  76.4 KBName:  IMG_6598.JPG
    1971 911S Coupe - Gemini Blue
    Dec 2013
    Connecticut/Florida
    I managed to pull out the defrost switch - its a two stage 901.613.045.00. Any help appreciated. Thanks
    Dec 2010
    Southold, NY
    Here's a start: http://www.early911sregistry.org/for...h+illumination
    Since you state your defroster switch is two-stage, bench test it to determine which terminal is activated by the first pull and which by the second.
    Junior Member
    Feb 2015
    France Europe
    Hi Simon
    Did you finally managed to find solutions ?
    I have a problem as well:
    Now my problem is :
    The back of my NOS fog light switch has 4 connections named :
    1
    2
    3
    K
    instead of:
    NR
    N
    58
    and I don't know what is the correspondances
    1 is NR , N or 58 ?
    2 is NR , N or 58
    3 is NR, N or 58
    K is NR , N or 58
    thanks for helping
    Banned
    Nov 2004
    Scottsdale, AZ
    Quote Originally Posted by Donzenac View Post
    Hi Simon
    Now my problem is :
    1
    2
    3
    K
    instead of:
    NR
    N
    58
    1 is NR , N or 58 ?
    2 is NR , N or 58
    3 is NR, N or 58
    K is NR , N or 58
    thanks for helping
    Pretty sure the proper original switch has the same numbers that the wiring diagram indicates. Maybe post a pic of your switch.
    Junior Member
    Feb 2015
    France Europe
    Hi Frank
    here is the (one stage) fog light switch nos part 901.613.503.20
    The back of my NOS fog light switch has 4 male connections named :
    1
    2
    3
    K
    I have in my left hand three female wires
    White one
    White / yellow
    Brown
    where do they go ?
    The wiring diagram that you posted in #15 showed a 2-stage (controls both front fog lights + rear fog lights) switch 914.613.451.10 = 911.613.027.00.
    The NOS switch that you bought in post #26 is a 1-stage (controls only front fog lights) 901.613.503.20.
    Here are the factory wire connections for your NOS switch being used to control front fog lights in a SWB car:
    Junior Member
    Feb 2015
    France Europe
    Jimmy you save me !!!
    thousands thanks
    Where did you get this wiring diagram from ?
    I drew it myself.
    Good luck with your lights!
