Results 1 to 2 of 2
Thread: Question on front trunk relays
    Dec 2013
    Connecticut/Florida
    Hi,
    I have a 1972 T that has both factory AC and also came with Fog lights (Fogs were removed at some point). I am now re-installing the fog lights and want to ensure its done factory correct with respect to the relays. Below is a photo of the front fuse and relay panel in my car. As you can see, there are two relays, one is attached and one is hanging off the panel. I am trying to figure out which relay is for what. The car was repainted, so its hard to tell where the hanging relay would be attached.
    Also is a picture from a repair manual that appears to show the various iterations of relays depending on options like AC etc. It implies Horn is at the bottom - but then it gets confusing with some iterations showing Fog and AC on the same relay and others with AC having its own Relay.
    Any help on how I can figure out which relay does which?
    Perhaps I am also missing a relay for the fog lights?
    1971 911S Coupe - Gemini Blue
    Pull each relay and see what doesn't work,,,,or pull the tape back a little and see what color wires are there. Horn uses black and yellow.
