Results 1 to 10 of 12
Thread: MFI micro switch replacement- Does it require system adjustment?
    Apr 2011
    N.Calif., south of SF
    Found the MFI micro switch not functioning allowing a loud backfire on trailing throttle.
    Tested the switch and found no difference between depressed and released postions, measured at the 2 electrical connectors.
    About to replace the switch- Does it require system adjustment? Or can it simply be replaced?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    I just replaced mine. Economy definitely improved,but I rather missed looking in the mirror as the scenery was lit up by a three foot flame!
    Sep 2006
    San Francisco
    No adjustment needed, unless you monkeyed around with other settings to compensate for the lack of a working switch. By the way, I think there may be some tutorials somewhere on how to open the switch up and repair it, if you're so inclined. IIRC, there are some soldered connections that fail over time and are the most likely culprits.
    Also, it shouldn't make any difference, but the way I've tested it is to rev to 2500-3,000 rpm, then push the plunger. If the rpms don't drop to idle then the switch is not working. You may want to make sure your tabs are making good contact at the connector as a first, simple check.
    Jeff Jensen
    Apr 2011
    Made me laugh! I can see it!
    Thanks for the tips Jeff. I will go through your suggestions. No, havent messed with it. Been using this:
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Sep 2006
    San Francisco
    Thanks for posting; hadn't seen that.
    Jeff Jensen
    After switch is installed back screw completely away from switch plunger, then turn screw against plunger until a click is heard, then 1 turn further, tighten lock nut.
    Ed
    Why won't my screw reach the micro switch even at full adjustment, nothing looks to be bent?
    What am I missing probably some dodgy adjustments in the throttle linkages I suspect
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Apr 2011
    Thanks Ed.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Apr 2011
    Clyde- that would be my guess. Maybe compare you linkages to some others, close up pictures of the link lengths etc?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Jun 2011
    Bellingham, WA
    Boyer73S...which side of the of the linkage is the locking nut? I had to move mine to the switch side to get enough screw adjustment
