Thread: Light question
    Light question
    On my 73 911, when you turn on parking lights, my left headlight comes on dimly. All else is working fine. Just started happening today. Any ideas where to start?
    Thanks, Bobby
    Bobby Smith
    member #299
    1973 914/4 2.8 ltr. (FTD winner 2008 Charlotte Parade) (sold)
    1973 911 "Orangello"
    1973 914/6 GT 3.2 "Crystal Blue Persuasion" (sold)
    2011 Boxster Spyder
    1973 911 E "E GO" Metallic Green
    H4 has a parking bulb in it. Is that what you're seeing?
    Early S Registry #235
    rgruppe #111
    Clean the grounds, sounds like one bulb is trying to find a ground via another path.
    Senior Member mathieulecomte's Avatar
    Dec 2016
    New Jersey
    I would also check at the fuse box to make sure your connection are clean and no wires touching each other
    Thanks Tom, Ed, mathieulecomte and Johnathan. Funny, it's been so long since I drove this car with the lights on that I had forgotten my H-4's had the parking light provision. 4w bulb was the culprit.
    Bobby Smith
    member #299
    2011 Boxster Spyder
