Results 1 to 10 of 10
Thread: 1969-1973 rear sway bar mount?
    Senior Member tcsracing1's Avatar
    Nov 2015
    Somewhere in a galaxy far, far away....
    I am restoring two 1969 911T.
    One car has the rear sway bar mounts and the other car does not?
    Was it an option in 1969?
    I have new reproductions from Restoration Design for one of the cars. Wondering why the other car is missing them?
    www.tcspeed.com
    Nov 2004
    New Zealand
    Pretty sure The "T" (as the base model) came without sways unless specifically "optioned" or added later after purchase?
    Mine did not have them (sways or mounts), and had no mention of them on the kardex
    You are lucky with a 1969, you can get a kardex to tell you exactly how your car(s) left the factory
    It will answer a lot of questions and will tell you exactly what you may have...
    Sep 2012
    Colorado
    That does not look original.
    Nov 2015
    Quote Originally Posted by raspritz View Post
    this is what was left after we sandblasted an original paint car.
    It could have very well been added at some point however. I just dont know what to look for to see if it was.
    www.tcspeed.com
    Aug 2009
    SF Bay Area
    That mount was surely added by a PO and an idiot.
    A shockingly large number of 911s were not equipped with sway bars.
    71 - 73 cars came with a left rear mount as part of the fuel pump mount
    Whether they had a rear bar or not
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by tcsracing1 View Post
    welding looks like it was done by gas welding
    factory weld was MIG around the center hole and 3 or 4 short weld seams on the circumference.
    those two screws where used to hold it in position i assume.
    Nov 2015
    thanks guys.
    I have removed them for the metal work.
    i have decided to add the new reproduction mounts for the addition of the rear bar. (hot rod)
    Anything i need to consider in positioning them correctly?
    www.tcspeed.com
    Aug 2009
    SF Bay Area
    thanks guys.
    Make sure that you use the "updated" mount or better yet, mounts provided by Elephant Racing. The original mounts fail all the time, especially when stiffer bars are used.
    Jim
    May 2005
    Oroville, CA
    I agree with Jim.
    There is a reason that they were "updated"....Elephant are even better.
    The mounts take a lot of abuse especially with bigger bars. I have seen many cracked ones even on street cars with stock sway bars.
    When we used to put on new mounts at the dealership, we assemble the bar with them bolted on with bushings and control arms hooked up and then tack for proper alignment.
    You would be surprised at how many are welded on crooked just to have them removed and repositioned when the sway bar is added...
    Unless the new generation of welders magically can line them up by eye......
    H
    Nov 2015
    Quote Originally Posted by Harvey Weidman View Post
    I agree with Jim.
    H
    Excellent tip!
    I bought all my metal and the mounts from restoration design. I would like to think the mounts will suffice?
    www.tcspeed.com
