Results 1 to 7 of 7
Thread: Early 911/912 front bumper possibly SWB
    Oct 2005
    wash dc/ los angeles ca
    Early front bumper (steel ) no trim rubber or mounting bracketry no major dents bumps or bruises
    Appears relatively straight and rust free other than surface corrosion a good media blast and prep needed
    $650 plus shipping contact Bert
    Oct 2005
    bumperooni
    36 year PCA member
    Dec 2012
    Denver Co.
    You need to show where the bumper brackets bolt on to see if it is 65-68 or 69-73.
    2 Mtg Bolts Horizontal = SWB, 2 Mtg Bolts Vertical ='69 to'73.
    36 year PCA member
    Dec 2012
    Denver Co.
    That’s right. Also could kinda of see bumper to fender mount that does appear to be 65-68 but right side is not visible in photo. Seller should still show area of bumper brackets mount on bumper to verify.
    Oct 2005
    At the direction of prior posters I checked the mounting holes and yes it has two horizontal mounting holes so yes SWB ! if I get it blasted and epoxy primed I'll likely ask $750 thanks Bert
    Oct 2005
    Bumperooni
