Thread: Olklappe Oil Cap
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    Olklappe Oil Cap
    The oil cap on my 72 has been stiff and really hard to remove for some time now,
    On closer inspection it appears that some one has used a wrench to remove it at some time (not me).
    I feel it is time to replace it but am asking if the 72 cap was in any way different to other years (being external) ???
    Thanks in advance.
    Mark
    Apr 2011
    N.Calif., south of SF
    I was curious, like a tech quiz- this what I found on Stoddard's site
    PCG-207-271-00 Oil Tank Filler Cap with Gasket for 1972 911 PCG20727100
    http://www.stoddard.com/pcg20727100.html
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Feb 2017
    Auckland NZ
    Awesome, Many thanks Haasman.
    It appears to be the same as a fuel cap.
    If I cannot find a period correct I will get it from the "bird" as the anodising appears to be more accurate and had an oil sign
    http://www.pelicanparts.com/catalog/...pg6.htm#item20
    Mark
