How do I remove the cover over the seatbelt mount. I need to remove it. Also the plastic hanger piece.
Chris
Chris
1970 Irish Green 914-6 w/2.2S
www.reSeeWorks.com
Just slide the plastic cover up a little and pull the top outward, then slide it down the belt to expose the mounting bolt.
That's not possible if the bolt retaining plastic is not broken as it locks the plastic behind the bolt. Most are broken though.
You will need to gather up some material to pull it out of the back opening. Slide a flat ring spanner in there from the bottom and undo. One of the hardest quiz questions on a 911...!
https://www.facebook.com/Beltwerks-139610016684496/
S Registry # 1660
Le Belgique ST build.
http://www.ddk-online.com/phpBB2/vie...p?f=28&t=42628
Thanks. What about the coat hanger?
www.reSeeWorks.com
www.reSeeWorks.com
The bolt head going into the B pillar is a 17mm. Stretch I have fought this issue several times and your answer is great information, pull some belt threw the back of the plastic cover and that will give you the access to the bolt head.
Thanks everyone. I got them off.
Chris
www.reSeeWorks.com
Well done.
Ultra Blau is such a nice and unique colour.
Tony
