Thread: Circle floorpan pressings
    Hi guys please take a look at the 2 photos you will see the circle pressings are not present on the inside near the tunnel but
    but it is on the other , Can anyone tell if the extra pressing we all see out there are new floors . Do we know what is original and does it change through the years.
    thanks jonny
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    some when in modelyear 70 the extra indents where added
    thanks for the reply
    Senior Member MikeyC's Avatar
    Nov 2015
    Oxfordshire, UK
    It does concern me sometimes how many times I see new floors on pre-70's 'restored' cars with these additional press-forms still in. They should be removed really.
    Whilst we're talking floor detail, note also along the centre tunnel in your second picture, the 3rd square depression from the left, the one that's almost pyramid shaped. On an earlier car it's much shallower and has a form much more like the other squares. Not exactly sure when this change took place, but judging by where it is, I suspect it was something to do with gaining additional clearance for a later gearshift mech, but I'm sure someone can confirm.
    Mikey C. ESR Membership #3333
    http://www.mceporsche.com
    Glad you said that i have had mine removed but i thought i was just fussy .
    Nov 2015
    Oxfordshire, UK
    Smile
    Quote Originally Posted by Jonnydaz53 View Post
    Good man, not fussy at all. Be proud, you're doing it right
