Results 1 to 8 of 8
Thread: 1967 front screen tinted or plain?
    Jul 2012
    Kent, UK
    Hi I'm about to order a new screen for my uk the 1968 S, and am wondering if the front screen should have a tint or be plain?
    Help please, thanks Rich
    Rich
    68 911S
    mbr. 2393
    I think both were available, with tinted as an option.
    Nov 2002
    San Dimas, CA
    Tinted glass was definitely an extra price option in 1968. Here's a list which I assume was posted here originally by Eric Linden. Tinted glass is option 9480, 9481, or 9482 on the third sheet:
    Tinted glass: 9480, 9481, or 9482, above.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    By tinted, we assume you mean glass that is tinted across (within) the entire surface. Glass with a tinted "stripe" across the top (clear the remainder) is also available but was never original. What is the rest of your glass, tinted or clear? I'd choose based on that.
    Jul 2012
    Kent, UK
    Thanks Jim, rest of glass is clear, the choice is for a tinted strip.
    The other issue is the mirror mount on the new screen, certainly not correct, anyone know if this can be removed?
    Rich
    68 911S
    mbr. 2393
    Jul 2012
    Kent, UK
    1968 's' Distributor 0231159002 black label vs yellow
    Moved question to separate string
    Rich
    68 911S
    mbr. 2393
    Quote Originally Posted by Richsmith901 View Post
    You should get the one without the mount. The mount can be removed by carefully heating the area under the mount to soften the glue. I've seen glass guys do that,,,,however you can just as easily get it too hot and soften the plastic between the glass layers,,,better to get the non-mirror mount glass.
    May 2012
    UK
    Wasn't tinted strip across the top few inches a much later year thing?
