Results 1 to 7 of 7
Thread: 1965-66 901-01 911 engine
    Junior Member petescoach's Avatar
    Jan 2013
    NE OHIO
    Selling 901-01 engine. Asking 17k obo
    http://www.stoddard.com/Werkstatte/petes66engine/
    -Pete
    <a href="http://www.petescustomcoachbuilding.com/">www.PETESCUSTOMCCOACHBUILDING.com</a>
    Engine number reference = 901787
    Peter Kane
    '72 911S Targa
    Jan 2013
    NE OHIO
    Still trying to find this a home.
    Pete.
    -Pete
    Nov 2002
    San Dimas, CA
    It still has the original style chain tensioners--that's interesting.
    It probably came in a car built in June or possibly early July 1965.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    Feb 2012
    Netherlands, Leiden
    Makes it a model year 1965 engine? Not a 1966?
    Nov 2002
    San Dimas, CA
    The '65 vs. '66 distinction may not be as big a deal for engines as for cars but yes.
    From the lists in this forum, the cars with the closest engine numbers were:
    • Chassis 301708 Engine 901804 Build date 1-Jul-65
    • Chassis 301780 Engine 901799 Build date 8-Jul-65
    FLYWHEEL
    But, engine # 901787 came after the change from the "6 volt" flywheel (gear tooth modulus of 2.5) to the "12 volt" flywheel (gear tooth modulus of 2.11). The last "6 volt" engine was 901638. Most--but not all--1965 Model Year 911s came with the "6 volt" flywheel.
    Of course, finding a 12 volt SR17X starter with the "12 volt" gear is easy while 12 volt SR17X starters with the "6 volt" gears are rare to unknown.
    CARBURETOR JETS
    Engine # 901787 should also have the most common middle set of carburetor jets:
    CENTER LUBRICATED CAMSHAFTS
    The last engine with the center lubricated camshafts was 303069.
    Jim Alton
    Torrance, CA
    Jan 2013
    NE OHIO
    Price drop. 17k for everything
    Thanks Pete
    -Pete
