Thread: Fuel tank 14mm Banjo with elbow and 8mm stub pipe
    Hi all,
    I am looking for the banjo elbow connector that goes on the fuel tank.
    Part number is 90135604900 - should be M14 with an 8mm stub pipe.
    Anyone have one spare?
    I can only find a M12 here with a 8mm stub pipe. The M14 part has a larger 10mm stub pipe.
    This type but I need M14 with 8mm tube size for the fuel hose.
    bump - anyone help with this?
    Belmetric may be able to assist you. They carry a banjo fitting with a shorter hose barb...
    https://www.belmetric.com/eye-fittin...ng-p-4428.html
    Over on the Bird...BoxsterGT (Len at Autosportengineering dot com)may be still making these, post #5...?
    http://forums.pelicanparts.com/porsc...k-fitting.html
