Results 1 to 10 of 64
Thread: '67 911 hot rod build - Metal Restoration
Hybrid View
    Mbr 3268 Fixer's Avatar
    Jun 2015
    Philadelphia area
    This past September I started repairing a pelican member's '67 911.
    It's not a matching car. Originally light ivory, the owner is changing the color but not altering it's SWB slim hips.
    We'll be putting a 3,2/G50 in this car.
    Here is what we started with, a typical East Coast car in terms of corrosion but straight. It's had bad prior repairs though.
    Matthew J. Mariani BSID, Member 32689
    Haverford Pennsylvania
    Jun 2015
    Philadelphia area
    Removal of suspension and former metal repairs in prep for media blasting above. My renderiing is pretty close to the green my customer has always wanted and he entertained the idea of red leather inside.
    Jun 2015
    Philadelphia area
    I repaired the floors and started with replacing the front latch panel. I prefer Danske but the front latch panel by RD is really nice quality. Well over 100 pinch welds to drill out to free. I remove the remaining rust with acid as i work.
    Jun 2015
    Philadelphia area
    More of the same
    Jun 2015
    Philadelphia area
    Cavities are sprayed with a zinc primer i mix. Interesting how when you tack this panel, you end up tacking exactly where the factory did to set in place.
    Jun 2015
    Philadelphia area
    Move to the front inner fender and A pillar after I prep the latch panel to protect it until epoxy.
    The first pic moved out of order. It's the trimmed lower A pillar.
    Note there will be zinc in that cavity. Zinc will migrate on its own to bare steel over time so it'll continue to protect. Porsche engineers learned this in the late 60s.
    The rocker sections intersect with the heavier gauge front inner fender sheet metal. It's really important this is welded nice and hot. The bead was left heavy by the factory there (by your foot)
