Restoring my 66' and bought new door stops from the dealer. Thought this would be a 5 minute job .
Installed the driver side (oriented correctly) and when I went to close the door, it wouldn't budge. So I thought maybe the stop was just locked up and needed a little more force to get it started as it was new. All that did is bend the arms of the stop.
Do I have the correct stop for a 66'? Do I need to modify a brand new stop to make it work? Thanks
