Thread: Early BEHR A/C Vents and Blower Housing
    Member sbartmess's Avatar
    Dec 2015
    NW Suburbs of Chicago
    I'm looking at the Electrocooler A/C system for my '67 Coupe. Without a factory blower motor assembly in the SWB coupes I am looking for a way to get supply air in to the cabin that looks like a factory or dealer install (vs. ditching the clock for a vent or worse). I would like to buy a Behr under-dash vent set up. If you have one from a car that you've removed you want to sell, please contact me. Willing to consider cracked/damaged goods for use in fabrication of new or repair.
    Scott Bartmess - Mbr. No. 3344
    65 356C Cab
    67 911 Sunroof
    71 914-6
    18 991.2 GT3 Touring
    Seeking Engine Case No. 911867
    Dec 2008
    Black Mountain, NC
    Scott, I have a Porsche-Air unit I am removing from my 67 912 SWT, it is a working under dash unit with fan, the AC condenser mounts to the engine lid, obviously compressor mounts wont work for you. This unit did not have vents drilled into the dash or glove box door as some did. drop me a pm with contact info if you would like Pics. will be traveling next week.
    and if his doesn't work I've got an under dash from a 67 911
    Does the 67 version work on a 71?
    Curios the differences
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    Dec 2008
    Black Mountain, NC
    Work or period correct would be the question, work yes period correct, not for 71. happy to send you a pic on the 67 made by CoolAir out of Miami if you would like to see it as a reference.
    I've got a nearly complete system from a pre-'69
    It is an under dash unit. No mods to dash proper.
    Interested ? Can provide pics after Tues.
    Rory rgalla9146@aol.com
Tags for this Thread
