Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Rear window defrost/repair question
    Aug 2010
    Colorado
    I had the rear window on a 69 going to media blast removed. The defrost wires weren't connected and we found the prongs missing. Does someone sell replacements and can they be soldered back on?
    Chris
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    Aug 2010
    Colorado
    Does anyone sell the prongs that are missing on the rear glass? Has anyone had success soldering them back on?
    I looked at a 70/71 rear window and it had 3 connections per side. This car is a 69 and has one continuous piece on each side.
    Chris
    www.reSeeWorks.com
    May 2006
    CT
    Hi Chris
    You might check the heating elements for continuity before you have the tabs soldered back on. I found that almost all of the elements on most of the early single windows I checked were damaged and did not conduct. No easy fix for that as best I know.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Aug 2010
    Colorado
    Good idea thanks.
    www.reSeeWorks.com
    Also when checking for continuity use a piece of tin foil as the sharp points on the meter tester will damage the fragile horizontal lines . They can be easily broken and damaged .
    There is a company that sells repair liquid with high silver content.
    Lines can be masked and painted with their material.
    I bought some but have not tried it yet.
    You might need to buy another cheap window to get the tabs.
    Obviously the 3 contacts is for a 2 stage defroster and the 2 contacts is for the single stage.
    This will also need to pair up with the relay ...either single or 2 stage.
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    Also took a good look at your horizontal defrost lines, they look pretty broken and deteriorated .
    Don’t think you will get good conductivity.
    Let us know and hope for the best.
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    Oct 2014
    near Champaign, Illinois
    About 18 years ago, I bought a kit at Auto Zone to repair weak/broken defroster lines. The kit had tape, a cardboard pattern with a long line in it, some sort of paint that conducted electricity and a small brush.
    I used it to repair the rear defroster on a Saab 9000 I had at the time. The kit actually worked and I had a working defroster. But, the lines looked kinda sloppy and were noticeably bigger than original. Maybe with the glass out of the car, it might be easier to be neater.
    So, there is a kit out there.....somewhere.....
    Good luck!
    Jay
    1946 Willys Army Jeep
    1956 356A Cab
    1957 356A Speedster
    1959 Austin-Healey Sprite
    1962 356B Notchback
    1969 911T 'Speedster'
    1971 911S
    1974 Ford Ranchero
    1986 911 Carrera Cab
    1993 Audi V8Q
    2001 Mazda Miata 'Daughters Car'
    2008 Audi S6
    2018 Panamera 4S 'Wife's Car'
    Senior Member 911kiwi's Avatar
    Feb 2003
    Auckland, New Zealand. And Los Angeles, USA.
    Hi Chris,
    I used this to reattach one of my rear window defrost terminals.
    Wasn't having much success with the soldering iron and was concerned that the concentrated heat might crack my older glass. Worked fine. Sets hard and conducts current well.
    Made in MA. Most electronics stores should stock it.
    Gary
    Kiwi
    1972 911S
    1967 912
    1959 356A Conv D
    Early S Registry # 306
    Dec 2010
    Southold, NY
    40+ years with my car and I don't ever remember turning on the rear window defogger. Is the effort of repair really worth it to you?
    Aug 2010
    Colorado
    Quote Originally Posted by ejboyd5 View Post
    I'll have to ask the owner of the car.
    Thanks guys you are a great help.
    I just hope I can find some tabs without buying a whole window.
    Chris
    www.reSeeWorks.com
