Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 30
Thread: Rear window defrost/repair question
  1. #11
    Aug 2009
    SF Bay Area
    Quote Originally Posted by cmpski View Post
    I had the rear window on a 69 going to media blast removed. The defrost wires weren't connected and we found the prongs missing. Does someone sell replacements and can they be soldered back on?
    Chris
    Chris
    Don't bother. All you will do is waste a bunch of time and possibly a small amount of money. I've got 50 of those things and I'll bet not one of them works. The only good thing about that glass it that it is not a later "2 stage" heated glass that would be twice the PITA to try and repair.
    Jim
  2. #12
    If you really want to repair with new tabs check out Planned Products in Boulder CO.
    They show a defroster repairs . There is a photo showing the tabs .
    Also other defrost repair items .
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
  3. #13
    Nov 2002
    San Dimas, CA
    I had a connector tab fall off the rear window of my Boxster (2003 was the first year with a glass rear window) and I believe I fixed it with Permatex® Rear Window Defogger Electrically Conductive Tab Adhesive from a Friendly Local Auto Parts Store.
    It wasn't all that difficult and the rear defrost works (although a couple strips may not be heating up). If your windows are out of the car it should be easy (compared to working under a Porsche rear window).
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
  4. #14
    Senior Member tcsracing1's Avatar
    Nov 2015
    Somewhere in a galaxy far, far away....
    interesting.
    i will be installing my 1969 rear window next month.
    i should see what condition my rear window defrost is.
    www.tcspeed.com
  5. #15
    Dec 2015
    Bordeaux, France
    Hi, I don't know about the heater wires since I never could find a good solution, but it's easy to solder the tabs back on. Glass holds well to heat and I have soldered tabs back on a tempered glass without problems.
    Good luck, and let us know if you find a solution to the heater wires on the glass
    ____o0o____
    1972 Targa 911S (one day), silver gray (maybe), member 3337
  6. #16
    Dec 2015
    Bordeaux, France
    ____o0o____
  7. #17
    Aug 2010
    Colorado
    Thanks everyone. This has been a very interesting thread.
    Chris
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
  8. #18
    I had one missing tab. Fabricated a duplicate based on other remaining, solder on just fine. Tinned the copper tab prior to soldering on glass. Had to move down slightly due to damaged silver tape where prior tab was located.
  9. #19
    Wink
    Ok, glad I found this thread. My defogger wasn’t working, and the wires didn’t look all that right as the car is modified. I’m about to install a new headliner, so I figured I take a crack at troubleshooting it before reinstalling the back window with the new seal.
    It’s a 2 stage switch
    3 terminals
    I have 12V +/- at all 3 tabs, on both settings
    The other side is grounded to the chassis
    I am not getting any readings/ohms/continuity across the windshield. What is the likelihood that all 3 elements, and every trace wire has an open lead?
    Can someone share a picture of where to ring out the wires, I’m sure I’m doing it right, maybe.
  10. #20
    May 2006
    CT
    The best way to test the heating elements is to use a test light and a 12 V power source. Connect the positive lead of the power source to one of the tabs on the end of the heating element and the negative end to your test light. Very gently probe your heating element moving away from the positive connector along the heating element. As long as the test light lights, you’ve got continuity. I found with most of these old defrost windows, the heating elements are damaged, often very close to the power input source. I have never tried to repair one.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
