Thread: Replacing rear trailing arms
    Oct 2010
    Stockholm/Sweden
    Lightbulb Replacing rear trailing arms
    Is it possible to replace the rear trailing arms on a pre 72 LWB with the gearbox in?
    Obviously the front bolts need to be cut off since they’re facing inwards but will new M14 bolt slide past the torsion tube from the outer side? Not keen on any fancy split after market bolts so will drop the drivetrain if necessary
    Jesse
    Porsche 935 DP1 Zirkelbach
    930/10
    Resale red
    Porsche 911, 1971
    2.5L on Webers
    Silvermetallic
    I have done it by using a thinner locking nut, so the locking part grabs the shorter bolt.
    Oct 2010
    Stockholm/Sweden
    Thank you Ed!
    Just for clarification, by sticking in the bolt from the outside, hence locking nut towards the gearbox?
    930/10
    Resale red
    Porsche 911, 1971
    2.5L on Webers
    Silvermetallic
    Yes, that's why the bolt had to shorter.
    Oct 2010
    Stockholm/Sweden
    Thank you for the clarification!
    930/10
    Resale red
    Porsche 911, 1971
    2.5L on Webers
    Silvermetallic
    Aug 2010
    Colorado
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
