Results 1 to 9 of 9
Thread: 1970 antenna repair - help
    The antenna on my 1970 911 stays frozen about 5 inches from surface of fender. I can't get it to go down all the way. It seems that something may have corroded internally down at bottom of stage 3 or 4. Is there a fix for this? Is there a way to coax it to recede all the way down AND extend out all the way. Seems that the 2nd stage is also not extending. Much appreciate input from antenna experts out there!
    Is it a Hirschmann ? from 1970 ?
    I have problems with my '69
    I believe that it is. Probably need to replace.
    I got lucky with heating the mast out of the car. Penetrating oil before and after. Don't hurry.
    Good luck
    Used advice from xsurfer. Penetrating oil did the trick. Got it dislodged and working fine. Thanks to xsurfer and Registry!
    Senior Member tcsracing1's Avatar
    Nov 2015
    Somewhere in a galaxy far, far away....
    is there any alternative to an antenna?
    i have new fenders that are not cut for antenna.
    www.tcspeed.com
    Apr 2008
    Virginia's Blue Ridge
    Quote Originally Posted by tcsracing1 View Post
    No radio...
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    Quote Originally Posted by Bill Simmeth View Post
    No radio...
    Now that's funny.
    My radio and antenna work fine but the thru dash speaker is total garbage.
    I used to get better clarity 50yrs ago talking to my friend via a couple of paper cups and a length of string.
    Mark
    Nov 2015
    so i assume i have to drill my new fender if i want radio...
    www.tcspeed.com
