Results 1 to 10 of 16
Thread: Nudge bar / Tow hook
    Dec 2011
    Monroe, WA
    I have what I believe to be an original nudge bar
    (experts please chime in here)
    See pictures for a non-flowery description.
    To be concours ready I'd restore it.
    $500.00?
    "Fahr drauf, bremsen ist feige!"
    The Netherlands
    One of the optical nicest options IMHO but how does it mount on the rear bumperettes> Do you need a special version of those?
    Kind regards,
    Cees
    The rear bumperettes are the same(except for the fact that a hole would need to be drilled in them to attach the bar), but if you want the black rubbers on the bumperettes they are shorter than the standard rubbers. In addition to that there is also a round rubber seal on each side that goes in-between the bar and the bumperette where the hole is drilled when you attach the bar to the bumperette. The factory called it RAM Protection, do a nerf bar search and you'll see pictures with the rubbers and without.
    Dec 2011
    Monroe, WA
    The grommets to mount the nudge bar are the same as the 356A overrider bar.
    They are easily obtainable.
    Jul 2011
    Chicago Area
    If you need the rear black rubber pieces they are the shorter ones used on the front not a special order.
    Mike Fitton # 2071
    2018 911S Carrera White
    Nov 2010
    Montana
    I seem to recall seeing this Advert or similar on this site advertised as bearing a Dent (defect) and asking $300 ???
    The Netherlands
    Thanks all for the info, so it seems not too difficult to get it mounted. Are the end threaded, must be I think but hard to see in the pics. Not easy though to get the dent out and get it properly re-chromed.
    Kind regards,
    Cees
    Pm on the way
    Jul 2011
    Chicago Area
    Is it possible to restore this bar, I don't see how you can get that deep ding out?
    Mike Fitton # 2071
    Oct 2013
    Kirkland, Wa
    .....SOLD........
    ".......to my friend Ravi Singh.....for a song and a dance......."
    Say it with an East Indian accent.......its much funner........
    Ravi
