Results 1 to 10 of 12
Thread: Michelin XWX 205/70/15 - few questions
    Nov 2014
    New York
    Anyone running these on the rear of their 911? Thinking about putting these on the rear with a 7in fuchs. My only concern is they may be a bit too tall. 185/70/15 on a 6in fuchs up front seems perfect but I'd like to run a staggered set of wheels and tires if possible on my 73.
    Nov 2003
    Sydney
    DG
    go for the retro Pirelli CN 36s for those sizings - 185/70 f and 215/60 r.
    the XWX are far too stiff in the sidewall and are made for heavier cars such as Daytonas,Boras and the big MBZ sedans of the day
    I had 2 sets on a '74 911 S and lost several bumping noises after moving to the CN 36s.
    just my 02c
    Dennis
    S Registry member 536
    Quote Originally Posted by gulf908 View Post
    DG
    just my 02c
    Dennis
    Did the 215/60/15 CN36 fit without rubbing on your 74? I wanted to run a set of my NB 74 911 with 7 inch Fuchs (not 7R) but think they might rub. Curious your experience?
    Nov 2014
    New York
    Quote Originally Posted by CVLCPorsche View Post
    My thoughts exactly, which is why I considered the Michelins.
    Nov 2006
    S. F. Bay Area
    I bought a silver anniversary 911S new in '75. One of the first things I did to it was to put 7's and 215/60-15's on the rear. Fit perfectly, although the '75 USA cars did have a higher ride height than previous years...
    Brian
    S Reg #1032
    Senior Member NickP's Avatar
    Mar 2006
    Solana Beach, CA
    I also have 7” Fuchs on the rear of my 73S. I’ve always been told that 215/60’s won’t fit, even though my fender lips are rolled. I’ve used 205/60’s for years but the choices are pretty limited now. I’d like to get the CN36 in 185/70 but am worried that they will be stretched on the 7” rears and not look right, and that the 215/60’s won’t fit.
    Nick Psyllos
    S Reg & R Gruppe
    1973 Euro 911S
    1972 911T to ST
    I run 185/70-15 XWX on 7's at all four corners and have been extremely happy. A stiff sidewall makes for better cornering. Mine is a lowered 73.
    Bobby Smith
    member #299
    1973 914/4 2.8 ltr. (FTD winner 2008 Charlotte Parade) (sold)
    1973 911 "Orangello"
    1973 914/6 GT 3.2 "Crystal Blue Persuasion" (sold)
    2011 Boxster Spyder
    1973 911 E "E GO" Metallic Green
    Feb 2010
    San Francisco, CA
    I’ve run 206/60/15 mounted to Fuchs 7” on the rear of my 73. They were fine until the rear was loaded up in a corner and they rubbed up higher in the well. Great way to burn the paint. Swapped them out.
    I’d expect 215s to have even more of the same issue.
    E911SR & RGRUPPE
    '73 S Coupe #306
    Feb 2005
    Lake Tapps, WA
    The 215's will work on a 7R but not a standard 7. The offset is the problem.
    '67 911S
    '69 911S
    '70 911ST
    '73 911T Targa Signal Yellow
    '11 Spyder
    Early S#1097, R-gruppe #
    Senior Member 2.5MFI's Avatar
    Sep 2006
    Bend, Oregon
    I run 7's all around, Pirelli P6000's, 215/60 in the rear and 185/70 in front. Tight fit in rear with 930 brakes and had to use 12mm spacers. Narrow body 72.
    Mark Jung
    MFI Werks
    Early 911S Registry #972
    Carrera T w/LWB, MT, RWS, PCCB
    72 T 66 x 100 MFI Twin Plug Coupe
    R Gruppe #686
