Thread: LWB interior tar paper
    Banned
    Nov 2004
    Scottsdale, AZ
    What's currently available for tar paper for the floor? Technically matting, not paper.
    Thanks.
    Senior Member larwik's Avatar
    Dec 2003
    Los Angeles, Ca
    3M 08840 ... Tar-matting
    Hi Frank...Chris N up in PNW has done amazing work with this 3M 08840 material...It's not Tar"Paper" as such but this might be an option...on the inside floor pans, under hoods, inside the door cards etc, etc...just dull black finish..approx. 1.5mm thick ..not Alu-finish...not a lot of surface pattern...and you can paint it if you wish...
    http://www.early911sregistry.org/for...toration/page5
    Quoting Chris: "3M 08840. 10 sheets per box, which is plenty to do an entire 911. Prices range from $70-$100 for the box of 10 but they can be purchased individually.
    You will need a heat gun, a small vinyl flooring roller and some strong fingers to push it into all the corners. Heat is your friend, otherwise it can crack.
    I peeled off the outer layer of clear plastic so I can paint it when I paint the interior."
    Of course I bought a box "cheap" on the Internet for sound dampening...So now it's up to me!...Good Luck.../ Lars..
    Lars Wikblad...
    Early 911 "S" Registry # 527
    "R" Gruppe # 314
    Banned
    Nov 2004
    Scottsdale, AZ
    #youdaman
    Thanks!
    Senior Member BrentF's Avatar
    Sep 2012
    Toronto
    Here's a picture of the actual product:
    Brent
    '70 911S
    '68 TR250
    Dec 2003
    Los Angeles, Ca
    Frank... thanks' but #Chrisdaman ...Chris Nielsen, that is.../ Lars...
    Lars Wikblad...
    "R" Gruppe # 314
