Thread: finishing trunk front area?
    Senior Member tcsracing1's Avatar
    Nov 2015
    Somewhere in a galaxy far, far away....
    I have all the metal work completed in my front trunk.
    It is a mild hot rod. So the front trunk will be exposed with no carpet. Spare tire, leather strap etc..
    What is the general census on finishing the metal for paint? Seem seal it?
    www.tcspeed.com
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Epoxy primer. Seam seal where necessary! I’m an amature. I did this not too long ago and started with plain ol’ primer and changed over to epoxy; what a difference!! Much better.
    Shift Knob Maker
    Oct 2004
    Marysville, OH
    There are numerous threads on here about that, try the search function.
    Mark..
    As Cliff points out: Catalyzed epoxy primer on bare metal always (2 coats better than 1)! Then follow with whatever top coating you wish.
    Jul 2006
    Corvallis, OR
    I would absolutely put SKS in the front trunk as the factory did. Since it's a hot rod you don't need to go as heavy but I do it like the factory but just not as heavy for a hot rod. For an original car it goes on as thick as the factory did. You'll need good pics or an original car to show you where to apply it.
    72S, 72T now ST
    PPG DPLF Anticorrosion primer. Don't make it pretty.
