Results 1 to 2 of 2
Thread: FS: 911/83 74 ROW Carrera/73 RS full 2.9 engine with SCRS Kugelfisher MFI
    Hi All
    Selling the engine out of my 73 RSR tribute. It is a 74 ROW Carrera/ 73 RS 911/83 engine with 2.9 Andial Pistons running the MFI from the SCRS. The engine so doing about 500 miles and has not been run in yet so has never exceeded 5000 RPM. It is running 10.5/1 compression and is fitted with the following parts:
    SCRS Kugelfischer MFI pump
    New Injectors
    Twin plug heads
    Twinplug Patrick Motorsport distributor with twin MSD electronic ignition
    Modified cams (spec TBC)
    Titanium headers and RSR exhaust
    RS throttle bodies with high trumpets
    New alternator
    RSR clutch (tbc)
    As mentioned above, engine is still fresh and has not been fully run in yet. Can be heard running in the car and tested. Located in South Florida.
    Asking $60K for everything (pump alone is about 20 to 25k) including mounts, starter, clutch etc.
    DM me for more info and viewing, pics can be found on my Instagram feed rikard964
    Last edited by Rikard; 01-08-2018 at 07:07 PM. Reason: Removed words "Thinking about" as price is listed...Moderator
    Car plus engine will be at DRT in Miami on the 11th of February so can be heared running then. 👍
