Thread: WTB: 1973 and older front A Arms
    Hello I need a pair of 1973 and older front A Arms with bolt in sway bar mount.
    Thanks George
    Last edited by 72targa; 01-02-2018 at 04:45 PM. Reason: Moved trade item to WTT...Thanks!
    May 2006
    CT
    George
    I should have a pair. PM me with your email for pics and price.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    36 year PCA member
    Dec 2012
    Denver Co.
    The only ones that had a bolt on sway bar mount were 65-68 which are totally different than 69 and later. I have them and sway bar mounts if you are interested. 68 are a 1 year only.
    Thanks for helping me with this post. The bolt on sway bar mount is the type that has a bolt that holds drop link to A Arm. The 1974 that I have use a rubber donut and the sway bar goes thru it and not bolted on. Sorry for not giving a better discription for Porsche Experts. George
    May 2006
    CT
    Here you go....PM me for details.
    Tom Butler
    1973 RSR Clone
    1970 911E
    36 year PCA member
    Dec 2012
    Denver Co.
    Bolt on sway bar bracket.
    Here is what I thought you meant on the bolted on sway bar bracket. They were for 65-68 and bolted to the A arm where the ball joint bolts on to. If you want to use with the threw the body sway bar either 65-68 (SWB) or 69-73 (LWB) will work.
