Thread: Looking for DIY
    Looking for DIY
    Would like to pull speedometer angle drive from transmission case. Once I remove the hex bolt / set screw. How do I pull out the assembly? Any special tools to pull this out?
    S Registry #1280
    1970 911T
    1968 911 FWT
    1965 356 SC
    Banned
    Nov 2004
    Scottsdale, AZ
    No. Just use your man muscles. Time and a slight interference fit from an old o-ring make them a little stubborn to pull out. (Assuming you do have the front trans mount off?)
    I'd drain the oil first.
    Restoration newbie.
    Jun 2007
    San Francisco
    Mine was stuck hard, I bought a M24x1.5 AN10 adapter for $5 on eBay, drilled and tapped the AN side for a slide hammer and slapped that little bugger out.
    Name:  Screen Shot 2018-01-08 at 9.51.48 AM.png
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
